Fleetgeo
- Joined
- Feb 14, 2017
- Posts
- 125
- Reaction score
- 46
my 2001 Yukon Denali 6.0 is having a intermittent issue
I was driving one day and out of no where the check engine ligh started flashing and I came to a stop it started to shake real bad as if it wanted to shut off the voltage gauge kept fluttering to lower volts , once income to a complete stop it's shake then turn off it'll turn back on with no problem and idle fine for about 30 seconds then I'll drive and it'll start again it will hesitate and feel likes its sputtering it does this for 1 week then 1 week it drives fine with no problems
I changed the fuel pump and filter , plugs and wires , sea foam the tank , I replaced all vacuum hoses , water pump , starter , thermostat
