Intermittent shaking at red light
tinin
2014 Yukon 6.2
Slight vibration\shaking when at idle coming from the front end. Can feel it sometimes and other times nothing. Mechanic couldn’t recreate the shaking. Any ideas what it could be?
2014 Yukon 6.2
original owner? bought it used?
I know on mine I changed out the broken, blown out fluid filled motor mounts for solid rubber hummer mounts
as such occasionally now there is some slight vibration at idle, no biggie just get to feel those ponies a little better
OR VietVet
Multnomah Falls
Military
Willamette Valley
Welcome to the forum from Oregon.
I am assuming, I hate doing that, there is no CEL?
How long owned? Work done recently? Age of tune related components? Maintenance work needed or skipped? Like @Fless said.
MS09
I had intermittent vibration when idling/stopped. Then my car started shutting off when coming to a stop. Turned out to be a couple broken teeth in the timing gears. Had to replace the whole thing. wasnt cheap but shes running great now.
2012Ltztahoe
