Is it possible to adjust the brake pedal?
mattjones
VA
Is it possible to adjust the position of the brake pedal in relation to the gas pedal? My brake pedal sits significantly higher than my gas pedal, so I have to really lift my foot up a lot from the gas when I want to brake and I'd like to adjust it to make braking a little easier.
Gatorlac
Id like to get mine further apart from each other. I got big ass feet and sometimes I end up pressing both pedals when trying to brake lol
ccapehartusarmyINF.(ret)
Gilbert AZ
i believe newer gm vehicles have that feature were you can move the accelerator pedal closer or farther some do both as far as distance between them yer stuck
so gatorlac you end up hitting both pedals trying to break man what size feet you got im a 13 and ive never had that problem
plus if you do accidentally press both the break engages way before your throttle engages
Gatorlac
yea Ive got the powered pedals but I just leave em all the way down. Also size 13...guess I'm just lazy sometimes and don't move my foot far enough. Not really a big deal but annoying when it happens
mattjones
mattjones
VA
I wear 13s as well. I could never hit both though since my brake pedal sits so much higher than my gas.
Yukin Toad
