Is it possible to eliminate turn signal lights when headlights on ?
yukon1024
I don't like having blue headlights with amber corner bumper lights so it it possible to eliminate them from turning on when headlights are on.
Gzes
the drifting 2dr
Wichita tx
Can't you change them to white? And I wouldn't eliminate them since in pretty much everywhere its illegal and you will get a fix it ticket
Y
yukon1024
i had them but in the day u barely see them when turning signal light i could of cause an accident. I have to buy the clear corner ones but don't want to invest right now.
YukonXL04
The Riverboat
Arlington, TX
Okay, you are talking about the Amber parking lights correct? Not the actual turn signal... You can get "switchback led bulbs" just google it. It's white running light, turns amber when you push your turn signal.
Y
yukon1024
i had them but took them off cuz in daylight u couldn't c the amber.
YukonXL04
The Riverboat
Arlington, TX
Then you bought crappy ones... Lol because the good expensive ones you can see in daylight. You have stock turn signal housings?
Also you could make it work to be just a turn signal. Get a single filament bulb and make sure the socket makes contact with the bulb on the signal side and not the parking light side. You can flip the little wire on the bulb to the other side to make it contact the right one.
rizzuto
