Is Lifting Safe? How Much is?
bradmps
I have herd lifting my tahoe might not be safe because it can roll over easier.
Is it safe, and how much is safe, like 6 Inches?
What is your opinion? I want to lift like 3 or 6 inches, and get 33" or 35" BFG All Terrain Tires.
What's info on the safety
jdpber
GOLD MEMBER
The America
well legally anything taller than the assembly line in Detroit is "unsafe" and has the potential to tip.. but you have to go fast and hit a hard turn to tip over.. so basically use common sence and you will keep all fours on the ground.. i am 6" on 35s and have never thought i was going to tip. i have driven much larger trucks and suvs,, with over 15' lift and 44s and never put any of them on the side.. just take it easy on the on/exit ramps and you will be fine..
Cartwright
I'm at 10 and have never felt like I was gonna tip.
jerseyjonny
Jersey
haha im on a 6" with 35"s which stands 10" taller then stock and the only tipping i do is at the bar. o and as for the fenders they have been a mystery for a few years now, the shop i got them from went under a while ago.
