Is there a +1 size from 265/65-18 Z71 tires?
M
Mighty Hd
Florida
I wonder if just doing a leveling kit and factory size tires would look stupid??
Zed 71
Pacific NW
Sorry, I'm new to my truck and I have a 2wd, but I can't believe that GM would have a 4wd full size truck that couldn't fit 32's on it bone stock. I would have guessed in all honesty that you could go up to a 275/70 without issue, but it looks like that is way wrong after reading some other posts. Wow. Good luck with your search and your tire purchase. FWIW, I have stock 275/55/20's on my truck which equate to almost 32". I would think in a 4wd version I would have more clearance than what I have now.....
The Z71s "offroad" package has less room at the front wheel wells because of the front bumper caps. Yeah go figure :wtf2:.
I ran that way for a little while. It looked funny but not that bad.
M
Mighty Hd
Florida
Is there a kit to level just the front without having a cali lean? With most kits, it appears that the rear must be raised 1" as well so it levels out.
InTruckDesign
SW CT,
On a Z71 go with a 2" front spacer and it will be perfect. This is 2" front level with 18x9 XD Addicts, STOCK tires.
M
Mighty Hd
Florida
Nice! That's exactly what I'm looking for.
What 2" lift did you go with & tires?
InTruckDesign
SW CT,
Level kit is from Zone, bottom mount...tires are stock I think Bridgestone. All we did was level it, add the Addicts, tint and colormatched bowties...very simple yet set it apart.
STORMIN08
I found through some searches, that the lift spacer is roughly 1/2 the amount of lift.....I have a lower spacer that is 1", this should be 2" lift.
I do not want the cali lean so I plan to shave it down to 3/4" thick.
Gr8white
I'm sure someone has done it. If you plan on going this route please post some pics!
---------- Post added at 04:15 PM ---------- Previous post was at 03:21 PM ----------
Not trying to take over post... But what about 265/70/18 it would add 1" of tire. This is what I would like to do if possible.
265/70/18 is what I run without a lift on an 09 Z71.
STORMIN08
please post some pics......
I am currently looking at tires, as mine a have 33000 miles....
I am looking at 3 options.....
1. 285 /65 /18
2. 275 /65 /18
3. 275 /70 /28
my plans are to run a 2" front level only...if it sags, I will look for a 1" rear. I already have the 2" front, so I am using it.
any one with some accurate feed back please chime in.....I will also be running stock wheels.
Gr8white
Now that I think about it...Im pretty sure I'm running 275/65/18's. fwiw here are a few pics. I'll verify size shortly.ImageUploadedByTapatalk1367277634.928437.jpg
ImageUploadedByTapatalk1367277655.226142.jpgImageUploadedByTapatalk1367277672.359828.jpg
No lift/stock rims...fender liners were pulled slightly for clearance and I believe they may have trimmed lower valance some. Tire shop used hd zip ties to pull liners and hold in place. I think I'm going to remove zip ties and use a heat gun to manipulate the plastic to clean it up a little.
super_kev
