Is there a drain?
chauncey0337
MLT, WA
Is there a drain under the rear passenger seat? In the morning when I pull out of my parking spot, there's a small puddle of water right there. It's there even if it's not raining so I'm pretty sure it's coming from my truck. Any thoughts?
chauncey0337
chauncey0337
MLT, WA
Truck had to pee and couldn't sneak away to find a bush because you had the keys.
Ideally, Sumo is correct.
Sent from my myTouch_4G_Slide using Tapatalk
Lol. Would this happen even if I haven't used the ac in months?
bkboatnsleds
McHenry, IL
no. Sure its not just from moisture / dew / frost melting and following the body lines or what have you ?
chauncey0337
chauncey0337
MLT, WA
That's what I thought at first but the puddle is like right under the rear passenger side seat. I can't imagine the body lines leading dew to that area. Maybe I'll just get under the truck after I start it and check to see where it's coming from. Thanks for the replies fellas.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
do you use auto setting? it will use the ac atuomatically weather if you select it or not
erikrichard
I'll bet it's dripping out the exhaust somewhere, condensation formed in the engine that comes out when you run the truck. Next time you start it look down there for a couple minutes.
chauncey0337
chauncey0337
MLT, WA
No, I never use the auto setting. I like to be in control... I have control issues,lol.
Will do, thanks.
sumo
rhode island
then it must be hobos using your truck as a cover for somewhere to piss
MushroomMario
