Is this possible?
rolfsent
Cincinnati
I have a 1997 Yukon that has a factory radio and I was wondering if there is a way to wire up a amplifier and subwoofers to it. If so, than how?
_Dylan_
STAY FROSTY
Buy a line out converter. Walmart sells them for about $20. That is what I used when I added subs and an amp.
You have to pull the radio and add splices to each output for the converter.
rolfsent
rolfsent
Cincinnati
How is that holding up? I've heard mixed reviews about that particular converter.
_Dylan_
STAY FROSTY
It works great, I've had it about six months. I'm running 1000w rms off of it.
YUKON1999
i would just upgrade the radio for the ouput on the radio aint that great but if you do like it then i would go with that little convertor cuz i put a similar one in my wifes jeep it just splices in to the rear speakers then you hook up the amp to the little convertor but mine i have is half the size of that one and was almost $100
rolfsent
rolfsent
Cincinnati
I wouldn't mind having a aftermarket head unit if they all didn't look so bad/cheap.
YUKON1999
are you looking at single din, double din, or flip out. cuz i got a sigle din and i like it
rolfsent
rolfsent
Cincinnati
I'm thinking of keeping the stock head unit and just adding a bazooka tube to go under the back seats. I have one in my ext cab and it sounds pretty good, but that's also in a small space. I like the idea of putting my 12's but I'm wanting to keep all the cargo room now so I think a bazooka is the way in going. Do I still use this same converter?
_Dylan_
STAY FROSTY
The converter lets you hook up RCA wires to your amplifier. Most aftermarket stereos have rca outputs on the back of the stereo, the factory stereo doesn't.
I would build a box for under the back seats. I don't think a tube will fit.
BlueTahoe2001
Charlotte, NC
Aftermarket radio would be easier to wire everything too, but as already mentioned a LOC will work just fine. Be sure to make all your connections tight and solid so that none of your wires pull loose and or short out.
Colorado
