Issues
my 05
Eaton Rapids
I have a tighten gas cap message on my truck,also have service stabilty system is coming on.If I turn my truck then turn off he stab. system reboots also bought new gas cap..any ideas?
WildBill
for the gas cap you may crawl under and see if a vint line from the tank is cracked or loose. Also after youve been driving for a while stop and see if you smell gas underneath by the gas tank.
as for the stability, I not sure where to start. maybe loot at the fuses and see if anything popped that is related. maybe read the trouble codes. Also, not all codes can be read with the cheap code readers some need a tech II scan tool...only the dealerships have those.
Acts822
