Just a quick question
Multnomah Falls
Praise God for Rock Auto Parts. So, no "welding" so to speak, heat wrench to get the bolts/pins out. Been there done that. I lived in K.C., Mo. for lots of years and ran shops and they used salt on the roads. A nightmare. That problem went away when I moved to Oregon where salt is not used. Good call on the bushings as well. Hopefully the shop, if they do the work. will allow customer supplied parts.
SmileB44Death
SmileB44Death
Seattle
The "pins" are actually a bolt with a flat side. They typically seize inside the metal collar of the control arm bushings and because of this it all has to be cut out with a torch. My 05 Denali got this treatment earlier this spring. They were all completely seized (2 per upper control arms). You are looking at almost $150 in parts alone and that could go higher if they dont get a good deal on parts or mark the hell up on them for you. I got my parts from rockauto. You are probably going to need control arm bushings too. Not one of mine was salvaged. I wouldnt anyway. They are cheap enough and probably need replaced anyway.
Thanks for the information
overlookingsea
Salt Water Bath...
Seacoast NH
I went the way of the wrestler... using a DeWalt DCF899 Cordless Impact Wrench - with really Monster Torque, and a can of PB Blaster per side, I unfroze the four really nasty Anchor Bolts in 2 hours total work time.
Never having done any of this before, I went to a Youtube University video:
, on how to do it, and another video on best way to break free rusted bolts using the blast/tap w/hammer then forward/reverse method. It was flawless. At 211k heavily New England salted miles, these were not going to budge. When I finally did get them loose, the middle's were still rust frozen stubbornly clinging. Eventually, forward/back worked with that impact gun and I was able to quickly hammer them out the final way with a chisel. [I had tried a torch on a previous truck, but the shop was unable to free the two they tried, hence me doing it this way.]
I have to really stress just how rusted everything was. Rockauto's Dorman 13512 Anchor Bolts went in coated in anti-seize. Torque is 140 ft lbs on that nut, so it won't loosen on its own. BUT when I went to the shop for a four wheel alignment, the techs were gushing over just how easy it was to loosen these for adjustment ( I'd also replaced the tie rods in same job [with new Moog]).
I was able to clean up the existing cams to reinstall, but one of the tabs needed a spot weld.
I also replaced the control arms with Moog parts.
The original factory plastic plugs were firmly in place, so I'm guessing adjustment had never been done on this truck. ( I bought it at 205k miles - one owner).
It's a really great feeling to have done this myself and work with the shop on the alignment. No more mechanics taking advantage of me...
A couple of before and after pics attached.
uppercontrolarmrust.jpg 20170929_UpperControlArmCam.jpg 20170929_UpperControlArmCamAfter.jpg
Multnomah Falls
Pretty isn't it. Periodic silicone lube spray and penetrant will not hurt in the future.
Nix409
