Limited
- Joined
- Feb 14, 2010
- Posts
- 96
- Reaction score
- 14
What am I in for?... is this because I put 24's on my truck?
someone said:The problem is in the Valve Body, worn valve bore causing cross leaks. Either replace vavle body or service as needed. All transmission shops including this one should know how to fix this. There is also a cheat method to this fix, block the valve in the bore, but it will not fix the cross leak, mearly stick the valve to the on position. Works but can cause a firm lock-up engagement, drivabillity concerns may come up. Also confirm pump pressure with a guage at highway cruise speeds to see if pressure regulator boost valve is not at fault. Good Luck to all!
