Just Installed LED Halo Rings
DJVIM
Ontario, CA
Just installed these Halo rings from Umnitza not the crap that AAC sells. These seem to be built well and durable. Very bright even in the daytime. Let me know what you think.
CHOO CHOO
BackPagePhil
Manheim, Pa
I think they look good. Just depends on what look your trying to achieve. Great job though!
Sent from my DROID4 using Tapatalk 2
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
yes definatly better than the ones that came on the aftermarket ebay ones
BP RETIRED
LED or CCFL?.....
Also what type of aftermarket headlamps did you use for the install?...The oven trick work in seperating them? I use to be a buisness partner...if you will with Umnitza. (he still is using a picture of my car for his product.... http://www.umnitza.com/preadator-ccfl-angel-eyes-lincoln-ls-p-46.html ) Quality products. When I was in the game long ago..LED was getting fazed out for CCFL. Maybe LED is making a come back?
D
DJVIM
Ontario, CA
These are a LED halos not ccfl. These are the stock headlights. The oven trick did not work. Used a heatgun to get open took some work. I looked into the AAC halos CCFL but my buddy used some on his charger and his inverter went out a bunch of times and the lights were so fragile that they would break when installing or a few days after. I was made aware of umnitza because i used to own a BMW and everyone used a lot of their products. Hopefully these last because they were expensive $250 and I do not want to open them up again. I plan on doing the fog lamps because those rings also came with the kit but my truck did not come with fogs so need to get those first.
GalaxyBlackEsky
BlackedoutLT3
MD
Looks real good. To be honest I wouldn't do the Fogs a little to much. I think that looks Ricey. What you have done is a classy look.
mitchellowen
