Key Fob Help Needed
NASTY GM
Nor Cal
I need some key fob help, please. When I start or drive my Yukon then get out my key fob (lock and unlock the doors) works. If I go in a store or the house and come out it doesn't work anymore. If I restart my truck it works again. I replaced the battery in the fob so that's not the problem. Is there some sort of reset I can do?
Conor
"Bob's your Uncle"
Seattle, WA
Yes, I had the same problem when I first got my Tahoe. You can reset it on your dash computer. I can't exactly remember how to do it, but I am sure you can figure it out. I do know you have to hold down the lock and unlock button on the fob while you are doing it. But to answer your question, you can reset it, and that should fix your problem.
Conor
"Bob's your Uncle"
Seattle, WA
I ended up just running into the dealership and they showed me how to do it. It has just been a while since I have done it. I will srew around with it tonight and see if I can remember.
NASTY GM
NASTY GM
Nor Cal
Ok I tried the reset method according to the manual. Still having the same problem. Any other suggestions?
QUYHMK
