Largest Double Din Screen In OBS?
neosoul
Las Vegas
Trying to find out what is the largest screen anyone has been able to fit in a double din only installation in our tahoes. Looking specifically at the 96-99 tahoes
N
neosoul
Las Vegas
No one? Need to know if anyone has been able to install a 8" or 9" screen system in the double din conversion kits being sold on the net.
getonerd
dayton oh
i think an double din is 7x4
what is the model # of the head unit and look at the manual and look at the chassis size
Yukon96
Florida
You won't be able to go larger than a 7 inch, if ya want it to look right.
N
neosoul
Las Vegas
I was looking at Alpines 9" universal deck to stick in my tahoe, its no biggie that 7" is probably the max I can get in there, I've just had really good luck with alpines in the past and wanted to know if I could fit a 9" in the double din opening
AppocAlexx
Darth Appocalexx
Abilene TX
It would be really easy to measure the opening and basically put w/e size you want up the specs of your measurements and with a bit of cutting. Mounting are all basically the same with the double dins and size of screen doesn't always match the size of the whole unit. For example you will have a 9" screen with the body and components behind the screen in a case of only 6" or 7" for mounting purposes, this size is the norm only bc its takes no extra parts to fit the bigger screen. Not sure if any of this makes sense but for the guys that have installed many double dins it should.
In all you can pretty much fit any size you want, you may just have to make some mods to your dash for it. And with a little bit of patience and time you can make it happen.
Caddychris
