Trifollower
- Joined
- Apr 19, 2016
- Posts
- 2
- Reaction score
- 0
2011 Tahoe LT
I am leaking coolant from the surge tank at the bottom from what appears to be an overflow/over pressure type hole?
I noticed some small drops of coolant on the floor of the garage. I went to add coolant to the tank and when I took the cap off coolant leaked from the bottom of the tank. The engine was cold.
I replaced the cap thinking that was it. When I started the truck the next day coolant came out the bottom again but this time it was a lot. It then stopped.
The tank has never been empty and only took about half a quart to fill. The truck as never overheated and the temp stays solid at 210.
Is it possible the tank is bad?
Thanks
Thanks
