Leather seat touch up tip color . Easy cheap.
Woodblocker55
My Yukon XL has gray seats . You mix these 2 colors ( mixing on player ) you get dang close for touching up white spots where leather colors coming off . Brush on and wipe off with towel while its wet. Fills it in and looks great compared to all leather white spots.
Is it perfect no .. but it pretty easy to retouch up again if needed. If you have spots where kids car seats rubbed the color off ..you blend in color so its not a eye sore. Or you can buy now covers . But this anti-eye sore trick works . Was only $2 . Why this works you can adjust to sun faded seats also on your color when mixing.
Them spots were White in picture.
Sent from my LGL84VL using Tapatalk
Woodblocker55
Woodblocker55
Was there a before picture?
It worked to good on white spots I did them all. if it does ever come off I will get before shots . I think last owner had wife with serious sharp nails . Because the scratch's where on passager side and the 1 second row seat behind driver side. Driver and second seat behind passager side and 3rd row are perfect ..
Big Mama
Virginia
Did you also run across areas that look like they’re faded? Mine is black and most is ok but I have spots on the driver door and the back of the driver seat where people grab to get out that are white but no scratches. Nothing I’ve used has taken them off so I’m assuming the color is gone
Woodblocker55
Woodblocker55
Im still working on mine here I noticed a bit of more cleaning with a brush and meguiars cleaner and conditioner. Took alot of dirt off the very small cracks and lightened them up alot . That paint work good to cover up white spots. But white you have must be true fading so google the leather dye they have that might fix it. Mine are like cracks is leather where color came off and whites showing .
Gray paint covers it . [emoji106]
Try using this. I used to use it on my black leather seat bolsters, and it worked for me. Don't use the liquid, this is the paste type.Open_black_Kiwi.JPG.jpg
