LED bulbs from Hyper Automotive (Devs93)
95escahoe
I recently picked up some LED bulbs for my instrument cluster from Hyper Automotive, on the forum they are known as Devs93, got the stage 5 blue LED bulbs and picked up the sockets off Ebay, cause mine had the bulbs soldered to the sockets, they came out mint, was kinda hard to get a pic of them (that is why the left side of the cluster didn't look as bright its consistent on both sides in person and is very bright), so if anyone ever needs any LED bulbs for there truck go to http://hyper-leds.weebly.com/ or contact Devs93
xanatost
Lafayette, La.
Looks sweet! One day if I ever get a steady dam job I'm going to get me sum. Keep up the good work.
96redsport
Altoona, Pa.
Looks good. Did mine blue this past spring. Even replaced the indicator lights too. However after I did that, the ABS and Air Bag light stayed on... :/ Not sure what that is about..
1Agerry
Supporting Vendor
i like that man! that's really nice. i might even do it to mine!
95escahoe
95escahoe
thanks man
---------- Post added at 01:57 PM ---------- Previous post was at 01:55 PM ----------
when I did the LED's in the cluster I replaced all the indicator lights too cause the high beam one was out and figured it was easy enough to do them all then, and don't have that issue after replacing mine, there just on in that pic cause I had the key in the in the position before starting
---------- Post added at 01:58 PM ---------- Previous post was at 01:57 PM ----------
thanks man, do it, nice easy mod
Devs93
Sorry to chime in late glad your happy with them !
I offer a 1 yr warranty on all plug in play bulbs and I am quite a bit cheaper than sbl..Ive done side by side comparisons of the bullbs and can garuntee mine are just as bright if not brighter. We are still a young company still growing but feel free to browse the site
www.hyper-leds.weebly.com
or look us up on fb as not all of our products are posted on the site
AZ Tahoe
Arizona
Your site is a little confusing when trying to order. I am looking to do my entire cluster in blue. Do you have a kit with all the bulbs I need for my 99 hoe
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you want the bulb equivalent of #194 for the cluster illumination. I belive six total. I would not change the warning light to leds at all. it can cause some issues with there applicable system. tho the parking brake warning light and drl one should have no issues.
96redsport
Altoona, Pa.
Don't understand how it would cause issues.... Isn't the voltage signal generated from the system to the warning lights??
95escahoe
95escahoe
Its ok man, just trying to put out a good word for you and send more business your way.
---------- Post added at 06:00 PM ---------- Previous post was at 05:55 PM ----------
your gonna need 6 195 bulbs in whatever color you choose, and more than likely you will need to pick up some 194 sockets off Ebay or wherever you like cause the factory bulbs were soldered to the sockets, that's how my 95 was, and while you have the cluster apart I would replace all of your warning lights to with the regular bulbs you can get down at Napa that was the only place I could find locally that sold them, Advance and Autozone just sold the bulbs not the bulb and socket since those are soldered too, and if you email him on his page or send him a text he can send you and invoice for what you want if that's easier for you
---------- Post added at 06:02 PM ---------- Previous post was at 06:00 PM ----------
x2 and plus the warning lights look fine the way they are it is not something that is on all the time and LED's would really help at all, I just went and changed all of mine while I was in there
---------- Post added at 06:02 PM ---------- Previous post was at 06:02 PM ----------
curious about this too
blanchard7684
