LED DRL's for a Denali....post links to what you've got
DenaliAK
DenaliAK
Colder than you
Alaska
Well, I finally got them in. They are brighter at night than the standard halogen bulbs, but it's hard to see much difference in the day. Here's a pic just after install for an indication. Not worth the $60 LED's I ended up getting....
I'll try to get a better shot of them with a real camera. They look pretty good, just wasn't that much of a difference. These bulbs might be good reverse lights, though, as they are brighter at night.
BillBlatt18
Latham, NY
make sure u use load resisters i didnt in mine and it started blowing out tons of diodes
DenaliAK
DenaliAK
Colder than you
Alaska
Hmm. I talked to the vendor and asked if I needed any of that, and he said I shouldn't with this particular bulb. Something about the way they are made, supposedly.
blktahoe26s
Silverhill, AL
yeah, you wont need any load resistors unless you using led turn signals like i do. i have an ALL led front end from HIDGUY.NET. heres some pics.
Slammedchevy01
Im trying to decide between hyperwhite and amber LED's for the front sigs....anyone got pics with HIDs on? The DRL is sold on ebay under 4114 specially for drl
blktahoe26s
Silverhill, AL
mine go back and forth between white and amber in the same bulb.....its called switchback bulbs.....my picture is above showing what they look like...i got mine from HIDGUY.NET. you are going to need load resistors.
DenaliAK
DenaliAK
Colder than you
Alaska
I like those switchbacks...that's pretty slick. Looks good!
BillBlatt18
Latham, NY
any info on load resistors ? i've always had rapid blinking
you can just modify your flasher module to eliminate that. Its behind the knee bolster under the steering wheel. there is a thread on gmfs about it dont have the link right now tho
---------- Post added at 07:59 PM ---------- Previous post was at 07:58 PM ----------
denaliak link to where you got yours? they look bright as hell
DenaliAK
DenaliAK
Colder than you
Alaska
