LED front turn lights blowing fuses
tcash78
I have a 2004 z71 and I purchased a set of LED turn signal lights from ebay. I have purchased this style for my blazer and had no issues. These however, as soon as i plugged them in and tested them; they blew the parking light and both turn signal fuses. I thought maybe i plugged them in backwards so I replaced all the fuses and tested again with the same result. Has anyone else had this type of problem? Again I have had similar style lights and have used bulb replacement style LEDs and have not had this issue. Can anyone shed some light on this?
Thanks.
NJ04HOE
Paterson, NJ
I recently had the same problem, the old set I had worked fine but there were a few LEDs that burned out so I ordered a new set to replace them. The only solution I came up with was to leave the small corner LEDs unplugged and they stopped blowing the fuses.
01TX_Tahoe
Semper Fi
Pasadena, TX
I recently had the same problem when I got my new ones. Changed the fuse from a 10 to 15 and worked fine, no problems.
NJ04HOE
Paterson, NJ
I just did that and they're all working now but I notice that the 3 led's towards the corner flash different from the rest when the parking lights are on at the same time. Is that normal?
Sent from my iPhone 4 using Tapatalk
01TX_Tahoe
Semper Fi
Pasadena, TX
When the lights are on they do that but when they're off they don't. I noticed the other day
Sent from my SGH-T999 using Tapatalk
Chadricckglenn
