LED tails problem
Oklahoma
I just trired to install my new LED tails but when i turned them on the running/brake light on the right side didn't work so i took it out and plugged it into the left wich was working and it started to work then i plugged them both in to their correct side and now neither one of them work wtf is the problem
all other lights are working both turn and reverse
BlizzardX23
Sacramento, California
too easy....so what you did then was you installed the plug upside down like I did the first time...then...after switching a couple of times...you blew the fuse...check the fuse block on the left side of your dash
killer20072001
Oklahoma
close it was the ones under the hood i checked the ones by the door thats when i came inside and posted this but i feel like a big retard for not looking under the hood first i bet thats what i did because i flipped the plug a couple of times
NJ04HOE
Paterson, NJ
Ha ha, that's the same thing that happened to me when I put mine on....I was pissed and I thought they were fried or something. Once I got it figured out I felt like an ass.
Glad to hear you got'em working right.
chistoso
Arizona
I thought you'd do that because I did too. LOL I included a sheet with instructions hoping you wouldn't have to go thru this.
ecordell
CordellDesigns.com
Merica
The way I see it, there is no need to feel retarded or like a *******, you didn't know. You attempted to do it, tried to fix it, then resorted to asking for help. In my opinion, you my friend are smarter than you give yourself credit for......
*My motivational liftup for the day*
dpont
