LEDSs headlights package
AngelXL
AngelXL
Heads up for those that order Fog LED lights.
A lot of companies try to sell you the 5202/H16 for 2016 Yukons.
I don't know if every model is different or suburban is different but the H16 will not fit on mines.
Check out your fog lights before you place an order.
There is a fog light with 2 slots this you clip on type and a fog light with 3 slots this one you do a 1/4 turn to take off or on.
motorswin
were there any issues with fitment? did you have to alter the light like with HIDs for the dust cover?
AngelXL
AngelXL
Nope! Fit perfectly on both. Highs and Lows.
WillCO
Castle Rock, Colorado
20161012_191102-jpg.67898
That heat sink clearly extends out past where the dust cap would go. How did you handle that? Did you drill a hole in the dust cap or just leave it off?
Also, how did you handle the passenger side, where the air filter box rests right up against the dust cap? It seems like there would not be room for that heat sink and the filter box both.
AngelXL
AngelXL
Did you get a chance to view the whole thread? Some pictures and explanation of the mod.
The ones on the bottom are the wrong ones. Fogs LED are for different model gmc.
debo4x4
My 15 Tahoe uses the PSX26 for the fog light so you might check that out. I did LED's in HI/LOW/FOG and used the fanless design so all components fit in the housing and I was able to close the dust covers.
tanguycryms
