LEDSs headlights package
WillCO
Castle Rock, Colorado
Did you get a chance to view the whole thread? Some pictures and explanation of the mod.
The ones on the bottom are the wrong ones. Fogs LED are for different model gmc.
I did read the whole thread, and I'm confused. You say that the lights fit inside the dust cover housing without issue, but the picture you posted, that I quoted above, seems to show the heat sink or fan protruding a couple inches past the dust cover opening. Based on that picture, I can't see how there would not be a problem.
Maybe it's the angle or something - just looking for clarification.
AngelXL
AngelXL
Those are the fog lights. There is no dust cover down there.
Only dust covers are on the high and Lows. Which those models 9005 and H11 worked fine.
The fog lights are wrong ones. Sent them back.
myoung84
I'm about to order the low beams for my 16 Tahoe. Does the ballast tie into the wires inside the light requiring you to run wires outside the dust cap or does the ballast plug into external wiring? It would probably make sense once I look at it, just like to be prepared...
And I assume no flickering or lamp out warnings? I come from the long history of Dodge trucks and they are a pain when it comes to lights.
AngelXL
AngelXL
I installed everything inside the dust cover. Remember I just did this mod. so far nothing but good things... knock on wood.
AngelXL
AngelXL
These are the ones I ordered for the fog lights
AngelXL
AngelXL
Is plug and play bulb.
To me. It matches perfect with the rest.
ChubbyMessiah
