LEDSs headlights package
myoung84
Installed these in my low beams this weekend, so far so good. Will probably do the highs and fogs just to match.
Sent from my SAMSUNG-SM-G935A using Tapatalk
AngelXL
AngelXL
Very easy to install. 60 watts is more than enough. Nice and bright.
DanW
I have 16 Yukon SLT. Did the License Plate and Reverse. For all of you who upgraded Lows and Highs with the LED with Heat Sinks.. are you saying that the new LED you installed with the fan/heat-sink and also the small black box with the power convertor all fit into the LOW and HIGH light housing itself and you were able to get the dust covers back on (and screw in completely) without any modification to the cap itself?
AngelXL
AngelXL
Yes, take a look at the couple of pictures. Plenty of room with no issues.
Make sure you don't turn on the truck while you have the air filter unplug.
AngelXL
AngelXL
No, why? This will be pretty much as any other SUV out in market.
I'll see if I have some time tonight and put my wife's SUV 2016 Lexus GX 460 with stock HID and pretty much at the same height. Hers are bright as hell.
MLG1998
Just making sure before I pull the trigger on lows and fogs. I can't stand being blinded by idiots with headlights too bright for street use. Thanks for the info.
AngelXL
AngelXL
Lexus GX460 HIDs Vs aftermarket LEDS
HIDs on the LEX are nice specially with the adaptive system. Headlights turns right or left or move up and down with the vehicle.
AFS adaptive front lighting system
tanguycryms
