Let's talk engines and trans
Alan H Stott
Utah, USA
People tell me I should go for the 6.0 L96 (Flex Fuel Version paired with a 4L80 trans is this a good combination for a 2004 Chevy Tahoe? I am not the most mechanically inclined individual so I am going to ask if that is even a possible pairing. I want to beef up my SUV and I am sure I need a new engine or need to rebuild my engine anyways so i figured I'd ask about what I should do.
Or is it possible that I could just Opt for a 6.2L vortec engine.
Which I know will need to be ran on 93 octane.
I am also wanting to keep my 4WD capabilities sl what am I doing in regards to this. I am asking so that I am fully aware of all I need to work on in getting this right. I mean I like the flex fuel tech but I'd be happy to take the better HP and torque specs too. I am simply shopping at the moment.
So y'all are aware my dad is an ASE certified master mechanic and I will have his help when I do this swap. So please help me learn as much as I can.
Yes it is but I'd rather have a 6-speed. I have heard about kits to make the Gen IV work in a Gen III but do not know what it entails, especially with regards to the cluster and brakes and such.
Welcome to the Forum from NH.
Other folks will chime in.
Alan H Stott
Alan H Stott
Utah, USA
Well I do plan on being active in the forums quite a bit. But I don't know if i am knowledgeable enough to give advice.
Dantheman1540
Sugar Loaf Mountain
6.0 4l80 combo is a proven workhorse and possible powerhouse if built with performance in mind. Both should fit and adapt to your Tahoe without any crazy undocumented modifications. Since your Tahoe is a 2004 I would steer away from a L96 and look for an LQ4 or LQ9 because they are the same generation and will fit without any modifications to your sensors or wire harness. L96s came in later year trucks and require a few things to be relocated not to mention they are typically more expensive.
You do not need to be knowledgeable to participate. Reporting and discussing any truck-related experiences on this Forum, good or bad, adds to our collective knowledge base. The more that you read and interact with folks on this Forum, the more that you will learn.
Alan H Stott
Alan H Stott
Utah, USA
Thank you for the engine suggestions. The reason i was thinking about an L96 is because it is the flex fuel type like my current engine but if there is better options then I'd prefer that over the L96 any day.
Alan H Stott
Alan H Stott
Utah, USA
That is the most welcoming statement i have heard in any forum. Thank you.
Dantheman1540
Sugar Loaf Mountain
This place is definitely more friendly than most other forums.
I believe the only real difference between the flex-fuel motors and non flex-fuel is the injectors themselves which are easy to swap out. However if your truck wasn't originally flex-fuel capable you will need a different fuel pump and an alcohol meter so the engine knows how much flew fuel its getting.
If it were me I'd find an lq4 or lq9 and save the difference from getting the older 6.0 and put a cam in it.
S33k3r
Dallas, Texas
Aren't the flex fuel engines sealed differently, to prevent the alcohol from destroying the seals?
Nix409
