Let's try this again...
HotCarl
ID/WA
Hey all, I have a quick question about wheel sizing and bolt patterns because I am a noob...
My rig-1997 Tahoe LT, 4x4
I am looking to get some aftermarket wheels. Right now I am rocking the stock aluminum alloy rims, tires are Big Foot A/Ts, 265/75/r16. These stock wheels are 16's, right? What bolt pattern do I need on the new wheels? And I don't know anything about offsets... I know there are six holes in the wheel and six bolts on my axles, but that's about it...
Brandon X
Michigan
Yes the stock rims are 16's. I have a 99 Tahoe LS 4x4 which is pretty much the same SUV as you, and here are the specs regarding wheels that I got saved on my computer:
'99 4WD Chevrolet Tahoe Bolt Pattern & Info:
Bolt Pattern: 6x5.5 (6x139.7)
Offset Range: 18 to 40
Wheel Size Range: 16x7.0 to 26x10.5
Stud Size: 14x1.5
Hub/Center Bore: 78.3
Hope that helps.
lowlows18
BrOnX, NY (10457)
Stud Size: 14x1.5
Hope that helps.
that better help..LoL
hapyspaz
Austin
Factory offset is +25
Any offset larger than that will cause the wheel to appear "sucked" into the fender
As te number gets smaller, all the way down to -50, it sets the wheel out away from the axle, making the wheel/tire stick out.
If you want a larger tire, especially wider, you may have to get wheels that will push them out. All depends on the tire, wheel, etc
994door
tallahassee,fl
a good aftermarket wheel back space is 4.5 inches it is good for stock an it also is what most lift manufactures speck out
MrsMfcknMcDonald
