List of Common Maintenance Parts - LQ4 Denali
Toadster
Folsom, CA
I wanted to pull together a list of common replacement parts - and using our 2001 Denali XL as a basis. Not all parts may fit your model - so double check first!
Please don't make this a thread about which parts are better than others, etc... let's just share ideas and best known products! :hands:
OIL CHANGE
Mobil1 5W-30 (5-qt) $25
or Pennzoil High-Mileage Vehicle 5W30 Motor Oil, 5-Quart $18
K&N HP-2006 Performance Wrench-Off Oil Filter $11
Mobil 1 M1-206 Extended Performance Oil Filter $8
ACDelco PF46 Oil Filter $4
FILTERS
ACDelco GF652 Fuel Filter $10.50
K&N 33-2129 High Performance Replacement Air Filter $38
ACDelco A3085C Air Filter Element $26
Airaid 201-712 Direct Replacement Premium Dry Air Filter $148
Active Charcoal ACDelco CF107C Cabin Air Filter $43
ACDelco CF104 Cabin Air Filters $22
ACDelco 24208576 Automatic Transmission Filter 4L80-E $26
IGNITION SYSTEM
MSD Ignition 32829 Super Conductor Spark Plug Wire Set $71
ACDelco 9748HH Spark Plug Wire Kit $49
8 New NGK Iridium IX Spark Plugs TR5IX # 7397 $55
ACDelco D581 Ignition Coil $30
EMISSIONS
ACDelco 213-939 Oxygen Sensor ~$51 shipped (ea)
ACDelco AFS106 Oxygen Sensor (right rear) ~$33 shipped
ACDelco AFS137 Oxygen Sensor (left rear) ~$47 shipped
FUEL SYSTEM
ACDelco 17113698 Multi-Port Fuel Injector $39
Denso 953-5059 Fuel Pump $250
Delphi CV10017 Idle Air Control Valve $80
COOLING
RADIATOR ASSEMBLY GMC 01-07 SIERRA 1500 2500 3500 YUKON XL 1500 2500 $121
Hy-Per Lube Super Coolant - 16 oz. $10
LIGHTING
High Beam HID Xenon Headlight AC Conversion Kit by Kensun - 9005 (HB3) - 5000K $89
Sylvania 9006 SZ SilverStar zXe High Performance Halogen Headlight Bulb (Low Beam), (Pack of 2) $46
Sylvania 9005 SZ SilverStar zXe High Performance Halogen Headlight Bulb (High Beam), (Pack of 2) $50
GMC Yukon XL Denali 01-06 / Sierra C3 99-02 / Sierra Denali 99-06 Parking Signal Light Rh US Passenger Side $26
GMC Yukon XL Denali 01-06 / Sierra C3 99-02 / Sierra Denali 99-06 Parking Signal Light Lh US Driver Side $20
BELTS & TENSIONER
ACDelco K040378HD Fleetrunner Serpentine Belt $24
ACDelco 38158 Drive Belt Tensioner Assembly $40
BRAKES
ACDelco 18A925A Advantage Front Brake Rotor $34
ACDelco 14D785CH Advantage Ceramic Disc Brake Pad Set $28
ACDelco 18A952A Advantage Rear Brake Rotor $40
ACDelco 14D834CH Advantage Rear Ceramic Disc Brake Pad Set $28
scoobyxj
Ok I actually asked the question in a thread I started, but for better reference I'll post my findings here instead. My question was if anyone uses an AC Delco (or it's other brand equivalent) PF61 instead of the PF46. They are for the most part the same except the PF61 is about an inch longer, and after doing some research has a slightly lower (30psi) burst strength.
Here are some specs I found on the two....
PF46 cross reference
Part Number: 51042
UPC Number: 765809510425
Principal Application: Various GM Cars & Trucks (75-76) (96-10)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 320
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
PF61 cross reference
Part Number: 51522
UPC Number: 765809515222
Principal Application: AMC (82-86), GM, Saturn (93-10), Jeep (81-86), Isuzu (03-09), Saab (06-09)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.526
Burst Pressure-PSI: 290
Gasket Diameters
Personally myself I went with the PF61. I run full synthetic 5W30 oil, don't rev the engine over 2,000 RPMs till it's warmed up, and feel the slightly larger filtering media area trumps the possibility of bursting the filter.
SilverSport
OIL CHANGE
FILTERS
IGNITION SYSTEM
EMISSIONS
FUEL SYSTEM
COOLING
LIGHTING
BELTS & TENSIONER
BRAKES
appreciate this...
Bill
S33k3r
Dallas, Texas
At some point I may get industrious and try to find the proper part numbers for these items. But, for now, I wanted to list them so I wouldn't forget them. And, you never know, someone more experienced than me may have these part numbers:
Oil pump and O-ring
Water Pump
Heater T at the firewall
Windshield washer reservoir
Cab Filter
Transfer case (4WD & AWD)
Seat Covers (Leather and/or Cloth and colors)
Head liner
Blend Door Actuator
Exterior, rear view mirror glass (not that it fails, mostly gets bashed)
Interior paint colors
Air Conditioning Parts
Fan/Fan Clutch/Electric Fans
