ivin74
05 NBS Nali
It all started 2 weeks ago, one morning I started the suv(started right away) and headed to the gas station to filled up, after the fill up I tryed to turn it on and it acted like it was going to turn on, but it did. It cranked but the battery acted like it did not have enough cold cranking amps.
Seemed like the battery died all of a sudden. Called my wife and she drove up and jumped started me and went on about my business. That issued did not happened again the rest of the day. Fast forward to this weekend it did it again. This time I took the battery to get tested (2 year old battery) and it tested fine. Put it back on and drove it 2 more days. Went to the store and back and as soon as I got home it did it again put the multi meter tester on it and it read 12.8 volts. This time I took the battery of my son's 04 Silverado and put it on my suv to see if it would do it again. Sure enough it did the same thing. Now I'm thinking it's the starter or the fuel pump. I can't believe it could the the fuel pump (Denso pump, 2 years old 20k miles on it). I decided to remove the starter and bench test it and it tested good. But since the suv has 190k miles I decided to just put a new one in anyways(AC Delco)
I tested the fuel pump and it was within the specs plus once the suv turns on it runs fine.
If I crank it for 3 or 4 time it acts like the battery is completely dead. If I jump it sometimes it cranks and sometimes it doesn't. What is weird is that it does the same thing if I start it by bypassing the ignition switch and relay.
I tested the alternator and it was good.
I was leaning towards a bad computer until I bypassed it. Any thoughts?
