Looking at buying this 2004
YukonLover
Hey guys, found a relatively clean and affordable 2004 XL. Its a few hours away from me. Its got a 5.3L and about 240K. The idle RPM along with the IDLE and under load OIL PSI readings. These shown videos with readings are all from the seller and gauges I haven't touched the truck yet. I realize gauges can be wrong, especially ones that are 20 years old. But the readings are still there, and the motor does sound loud. These motors are all low idlers, ive never seen an idle above 600, most around 400-500 range. This dude is sitting at like 900 at idle. Oil psi at idle is like normal high, warm is like 55-60 PSI, undler laod its dropped to 45 and average of 50-65 PSI. He was at idle in one clip, in park raised the RPMS, and the oil sending unit displayed 80 PSI and dropped after he left off the gas.
I am afraid with high idle, and high RPM we could be looking at blocked oil passages or lifter issues. But I don't hear the lifter in the videos. I attached the links to the videos, what do you guys think?
https://drive.google.com/file/d/1XZml7uM2OFDhVXeNUJPH3LPy-fPsUJfk/view?usp=drive_link
https://drive.google.com/file/d/1XbjDoT-_86QU0ilKxSMoSBQKXUKNmNlP/view?usp=drive_link
https://drive.google.com/file/d/1Xbz7Ie796sVSVJaOTOgPxz8lp9fskFt8/view?usp=drive_link
https://drive.google.com/file/d/1XlvgeWTy8prIhGWswhQ9kpvXFxWQ6TXz/view?usp=drive_link
https://drive.google.com/file/d/1XpbtdyTXLk5FHD3GmNJXBT_dgYiiDMMO/view?usp=drive_link
Y
YukonLover
Sorry. I fixed the permissions on the video. One of them will show you the PSI gauge registers at a pretty high 80PSI and holds. I have NEVER seen a gauge that high in my life. I know as oil gets warmer the PSI will drop as the detergents wear down and the viscosity changes. But this gauge is WILD. I have never seen a truck that idles at 55/60 warm. Most I've seen warm idle is about 45. My other engines have different values, but 10 PSI difference, this one is double, like 25 PSI difference. Let me kno what you think. I told this dude tomorrow I may come look. We've been planning this since before Christmas because he was out of town for a few weeks.
I cant access the videos. Its normal for oil pressure to be lower warmed up and at idle and fluctuate with rpm and the dash guage isn't as accurate as a mechanical test guage. The big issue is if it has lifter tick and oil pressure light on or flickering at idle.
strutaeng
Dallas, Texas
Is the truck in a cold area? I recently noticed my 06 Suburban idles kinda high in the mornings when it's cold, but haven't actually paid attention to the tach. Once I put it in gear it drops. I think that's kinda normal when they are cold.
I did bump up the idle a bit on the tune via HP Tuners. I installed a mild cam last spring when I freshen up my engine.
I wouldn't really be too concerned about the oil pressure readings TBH. I mean, doesn't seem like it's got low oil pressure, which is the biggest concern with an older/higher mileage engine.
Y
YukonLover
my 05 is 60 cold start, 40 hot idle, will hit 70 psi when hot wot driving down the road and stay there till i lift. so the oil pressure is just fine.
Several others have said they WOT at 70, and idle 55/60... but I've never seen or heard anyone hit 80 and it stays until they lift. That video, the engine had no qualms about getting to 80, shot right up there. I'm concerned with a pickup tube clog or lifters or maybe an oil galley clog with sludge.
Y
YukonLover
Not really. Those videos were taken at a temp of about 50-53 degree and full sun. Low for night was prob 33-36 degrees. I've heard of some people doing HP tuners. Hes owned it awhile and alleges nothing was done to it from him, however we've all seen the movie Matilda.
Dremar79
