Jason in DLH
Cheeseburger and Fries
So the user JustFishing gave me the idea to use AN fittings for a transmission cooling line repair.
I need some help determining the correct fittings:
This first photo is an example of the existing connection that I’ll be repairing.
What has been suggested is to cut the aluminum pipe (it’s 3/8”) and slide an AN fitting onto the aluminum and then use a 37 degree flare tool to flare the aluminum (shown below). I would then go ahead and do this on the other end of the line. I understand this process.
The next step would then be to get my new -6 AN braided nylon tubing seen here:
I would then go ahead and add a fitting such as this to this hose:
The problem I’m having is figuring out how to connect the two fittings together as they both appear to be female threaded.
If anyone can point me in the right direction for the fittings that I would need for the type of tubing (3/8”) and type of hose (-6 AN) to make these connections it would be greatly appreciated!
