looking for the correct way to go
pnap88p
i am running a 2008 ltz and every lift kit i look into says not compatible with auto ride kit!! what can i do to solve this problem, i am looking for a mid sized kit definitely not over 6 inches probably not even over 5.
any help with this would be greatly appreciated.
Momil
I am in the same boat. I am new to the forum but in my research the only kit that really seems to fit the bill is the Rancho 4" full suspension kit. The kit seems to run about $1900 to $2100 depending on where you buy it. They make a set of brackets that sell for around $215 that you add to it to accommodate the air ride set up. Also need shocks and then install labor. Sounds like 305/55/R20 is the tire size to go with if you want to use your factory 20" wheels. If anyone has any input or corrections to this please let me know as this is what I am looking at doing as well. Thanks!
P
pnap88p
it looks like thats about the only choice i suspect as well.
Momil
Pnap88p, I am going to try to start a new thread with a different title and list some specific part numbers, etc. to see if we can get some more information / input.
felixgun
Lafayette, LA
They make several 6" suspension lifts that accommodate the autoride factory suspension. My avalanche is an LTZ and I thought about doing a 6" lift but ended up going with a 2.5/1.5 leveling kit since I use it as a daily driver. Look up Fabtech they make a nice 6" kit and it's compatible worth autoride.
jeffrocates
