Loose rear driver side window
walther78
Just noticed the other day that my 03 with 56k on it has a loose rear window on the driver side. It doesn't rattle when it's up or down it just tilts about an inch towards the front or rear of the vehicle. Could this just be something down there that needs tightened up? The passenger side rear only has about a quarter inch play. My main concern is that I don't want it falling off the track, getting stuck, or shattering for any reason.
Has anyone had this happen before, if so what was the fix? I've seen quite a few vids on how to replace the motors and lift assemblies and am confident I could do that in an afternoon, but if that's not the issue there's no point in spending $ on something that doesn't need fixed.
clandr1
Dallas/Fort Worth, Texas
Sounds like a faulty window regulator. The plastic pulleys and parts can get old and brittle with age and if you have a pulley that's cracked or sagging, it could allow the play you're describing.
QUYHMK
