04 Tahoe with 250k on the engine. I have the 5.3 Z"flex fuel" engine. It has the typical oil leaks that most all 5.3's have. I have noticed, right after an oil change that my oil level drops quicker than once the oil is a bit older. To explain better....in the first 3000 miles of oil usage, I typically have to add a quart of oil. In the last 40% on the oil monitor, or last ~3000 miles of an oil change cycle, I barely have to add half a quart. Is it typical of the 5.3 to burn thru or leak fresh, clean oil at a much faster rate than used oil that has been in a for a while?
I've seen this happen repeatedly, so I think I am on to something, meaning this isn't just a one time flash in the pan. I've observed this over the last 12-18 months and 3 oil changes.
