Low Mpg even with add ons
gibbs6
Hey I just recently purchased a 167,000 mile 2004 4x4 Tahoe LT 5.3l and am extremely excited. I am coming out of a 2008 Altima 3.5l but needed more room and the 4wd.
Now I used to own a 2000 5.3l short wide bed sierra that I had did exhaust/optional cut out/cai/under drive pulley, notune, 18s that got 18 avg everywhere and would push 20mpg hwy, all at 200,000+ miles.
Here is the issue when I got the tahoe I would get right under 16 with mostly Hwy and some city(city for me is a 10000 person town, not dallas or anything). I expected around the same, it is heavier etc. I put a new K&N filter in it, corvette servo, electric fans, larger alternator due to fans, new plugs and wires, new brakes(they dont help mpg due but i put them on lol), and I got a BBP tune 93, we did the scan cable tune. After two full tanks of 93 and 600 miles I got 15mpg on what I normally would get 16, doing actually more highway, and 15.7 pure no traffic crusing 70 hwy (dont have a relative toward that) and no I was no harping on the gas cause of the new tune, my two dogs would not like that
I am in email talks with Justin. I am considering my vehicle even with the higher octane tune is not liking the 93. And I just bought a Airaid Modular Intake Kit, just the tubing from MAS to TB after i saw the results being just as good as all other CAI to see if a airflow problem is causing this.
I do not have aftermarket exhaust, didnt know if that was a issue, I like the stock sound. Recommendations to aftermarket exhaust for stock sound are welcome!
I know several are going to say its just heavier, older etc but my parents had a 2004 LT Tahoe 5.3l 2wd that would do 22hwy no modifications. They had bought it new and I drove it roadtrips before they sold it and it seriously did do that well. I understand mine isheavier but not that much ha.
I am planning on driving this vehicle till its gone, or I can hand it down to my son and have already slowly starting planning a newer engine swap into it once it gets issues or near 250k
I am just looking for reasons for the such low mpg and suggestions!
zieglerj-pdm-specialist
in 100 degree sandbox
I have a 2004 Yukon XL Denali 6.0 litre and when I got it , it would get 17 highway and 13 City so I went to work. I put a 6 PSI turbo on it, Cold Air K&N filter system. Pulse Plugs $22 a piece, 10MM Wires and coils. Magnaflow Exhaust minus the cats.SHHH. I also put the highest PSI pressure I could in the tires. I also replaced two tough to spin wheel bearings. Carbon Fiber Skid plate removing all the weight that I could. Did an airflow test on it where you take it in and they put visual air passing over the Vehicle. So now I drive the with Side mirrors tucked in because they are automatic. I replaced the rims and tires. 23" rinch wrapped with KuhmoSTX 305/40/23 which is 20 pounds lighter than my stock wheels. I Drive Steady at 70MPH and I get 26MPH and when I had a 30 mile an hour back wind I actually seen 30MPH and my city mileage is from 18MPH to 20MPH. Take Care of your ride and it will take care of you. Oh and I also you Mobil One 0w-40 protecting the engine and giving it smoother and easier component movement. I am an Oil analyst so I constantly check if there is any defects from using the lighter oil and Mobil 1 is the only oil I trust. I put 40,000 miles and no problem at all with the engine oil analysis. If you choose to go my route I'm not liable for anything that may happen to your vehicle this is only what I do because I can monitor and discrepancies. Take Care.
G
gibbs6
I am working with Justin on the tune and am going to try to run 89 in it instead of 93 to see if that will help. Other than that I bought a Airaid Modular Intake tube, and am still considering a higher flow exhaust if I can find one that will not be louder than stock.
Skylander
