Lowering yukon denali
bagged00
So in looking at purchasing a 2007 yukon denali. I'm wondering what it takes to lower these things. I see things about auto adjust and self level etc. So what exactly do I need? I'm thinking a 2 4 or 3 5 on 24s.
Thanks in advance
B
bagged00
Just found where Tony says they make 3 and 4" LCA.I haven't seen any thing about them through vemdors. Is this the same drop arm as a silverado? He said he feels it's a better option for autoride.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
for 5 inch rear set up on a denali you will need my set up. I can set you up with the front upper/lower a arms but i would upgrade to the moog balljoints which adds even more $$$.
go with spindles and my strut mod
OneTwo
Vancouver, WA
Has anyone done a 3 5 kit on a denali?
I went 3" in the front using the Belltech 2" spindles and McGaughy's coil relocators on the factory Autoride struts set to 1" drop.
The rear was supposed to be a 4" drop, but if I remember my measurements it went down a little more than that (probably due to worn out Autoride).
Anyway, here's a 3" front, 4-ish" rear drop on a Denali with 22's:
dcondon
