ls2 fans
justin.hughes
I am looking at adding e-fans to my 04 suburban. I know I can use lt1 and ls1 fans but what about ls2? I am wanting to use the factory plug in harness and not do any cutting of the wires
andrew383
indiana
What ls2 car are you getting them from??? The ls2 gto used the ls1 style fans and the vette's use a single fan commonly refered to as the "c6 fan"..It is about the same size as the ls1 dual fans but its a PWM setup and having a weak battery can cause problems..Im pretty sure the G8 gt's use the "c6" style also..
Just stick with the tried and true setups..Get a set of fans from a newer truck and a harness from Justin...
J
justin.hughes
The fans are off a GTO. I was told the 05+ fans would require a bigger radiator so I was trying to stick with a set of ls1 fans. I just happend to come across a set of ls2 fans. If they are the same then I will use them. Thanks
ScottyBoy
Shreveport, La
If you have a Suburban, you most likely already have the bigger radiator. Some Tahoes with the 4.8 and trucks with the 4.8 had the smaller radiator. I may be wrong, but i was under the impression that all 5.3 Tahoes and Burbans and all 6.0 engines came with the larger 34 inch radiator. I know my Suburban has the larger one, and I have a 2001 with a 5.3 engine.
Dr Tahoe
I have a 5.3L '03 Tahoe with the tow package.. It came with the 34' Discovered that while doing efans.
andrew383
indiana
Yes the gto's use the ls1 style fan..
Like mentioned above you may have the bigger radiator already..MY 03 has the 34" one already :)
wiser1
