87carl
- Joined
- Feb 21, 2016
- Posts
- 328
- Reaction score
- 169
In my opinion, it's not worth having adjustability unless you're going to be racing/tracking the thing. When it comes to trucks, simple is good. VVT is nice but a good 3-bolt truck cam, as Ken suggests, and you'll never miss VVT. I deleted VVT from my 6.2 with a Brian Tooley Stage 2 truck cam and haven't missed it.
On the heads, many LS heads will interchange, but not in your case. The LY6 uses rectangular ports, and your 5.3 uses cathedral ports on the intake. It also has offset rocker arms on the exhaust valves.
Side note: on my last cam swap, I started with a Vinci cam, but ran into some problems with oiling and bad lifters that damaged the cam (not the cam's fault), and ended up with the Brian Tooley cam I have now. Vinci makes great cams, but they're fast ramp and high lift, requiring dual valve springs and other upgrades. There's a thread here on the project if you're interested.
If you're interested in going with a Vinci truck cam, I have a brand new one here still in the box, complete with new matched dual springs, keepers, moly pushrods, and Fel-Pro valve seals I'd be happy to sell you for a good price. The only thing missing is the lifters, and for those I would use Morel 6504.
I do plan on deleting vvt. The adjustability is to advance cam timing so I can bring power lower into the rpm range. It's not something that gets adjusted often just during cam install then leave it.
The cathedral ports and smaller chambers are why I want the 243 heads if I change to the lc9 intake I can use those heads.
I haven't seen anything else about offset rocker arms? But I have seen few threads and a video of ly6 with 243 heads just nothing detailed. But those heads should also move power lower into rpm range also.
I want this to be as cheap as possible. That's why I was leaning towards the ls9 cam I can get one new for 140 dollars. And can sell the ly6 heads and intake. but if that won't work I will have to spend more money on a different cam or maybe keep rectangle port heads. The cams you mentioned are for the rectangle port heads and would only work if I don't change heads.
