Made some changes to the way you can order your fog light kits
Oscar@Hidguy
At HIDGuy we are always looking for ways to help you guys with your research and the way you order your kits. We try and help you make the best decisions when getting your kits but giving you the pros and cons about our Hid kits. We stand behind our kits and feel that these kits are the best HID kits that we have found and this is why our name is stamped on each and every ballast. Our 5202 HID kits are the same. We feel that we have found the best possible solution to the infamous "5202 bubbling and melting" issue. But we still give you the option to order your kits at 35 watt and 55 watt. It is just HIGHLY recommended that you order your kits at 25 watt as we have found that the heat of the bulb that is being generated is as close if not the same temperature as a stock OEM Halogen 5202 Bulb.
Now the question is...what questions do you GUYS have? We have add more photos so you can see the different between the stock OEM bulb you are pulling out of your stock housings and you can visually see how the fitment is with our bulbs.You also get to see how slim the ballast are that you are receiving along with the plug and play harness that you are getting when you add it to your order. Please keep in mind that the standard kit that you receive if you do not at add this harness comes with T taps to neatly splice into your stock harness. Now who wants to do that? Click the link below to check out the new page and please if you have any questions please post here in this thread.
Snotek27
