Map Light Replacement
bankswood
How do you remove the map lights. I want to replace them with some LEDs
soulsea
Bar
On the nnbs trucks you just put a flathead or something thin in there and they just pop out.
Is it more complicated than that on the nbs? :think:
B
bankswood
I guess I should done a better job of asking the question. Do you pry off the cover which houses the map lights and homelink buttons, etc. or is there some way to just pop out the map lights.
Another question.I'm new to the Tahoe / Yukon world and you guys have been great helping me. Can you explain the differencein nnbs and nbs
soulsea
Bar
obs = 1991-1999
nbs = 2000 - 2006
nnbs = 07+
And I'm not sure how your setup is with the map lights cause mine is a lil different ... but I'm sure someone will help you out asap. :waytogo:
MrBalll
West Texas
Pull off the thin clear plastic cover with a screw driver. Then pull out the bulb and the little reflective silver colored housing will fall with the bulb. If not just pull it out.
Reverse to re-assemble.
Jscan
