Max Tow Trailer Package on 2016 SLE
Yukon John
SE florida
For those that have wondered what the primary suspension differences are...here are 2: pics of left and right rear showing Air Shocks and Automatic Compressor Housing (Left Side)
I have the build sheet and have compared some of the RPO's. It appears that Max Tow also gets 3:42 Ring and pinion, Trailer Brake Controller, Severe Fleet Service Brakes, HD Fleet Service Oil Cooler and HD Fleet Service Transmission Cooler. That's a lot of upgrade for $450 !!
Kpwweb
Also gets a two-speed transfer case for 4wd with neutral and 4wd low.
Seems as though the rear springs are different.
Trans is also different somehow--at least the replacement units carry different pn's, maybe because of the t-case...?
motorswin
any difference between the coils in regards to lowering a max trailer vehicle?
Weber Dude
This is the reason why I got the max trailer package since I was getting the 5.3.
Denali16
any idea what the max weight the self leveling is meant to "lift". I don't want to over do it.
Yukon John
Yukon John
SE florida
I don't know for sure...but being rated to tow 8500# and 10% tongue weight being recommended...seems that 850# would be the max.
Cypress, TX
I would like to know this as well. I would like to do a 2/3 drop but was curious if the auto compressor would interfere. I also had a thought about putting a switch that would allow me to turn on or off the auto compressor. I'd like it to be level while not towing my boat, but not squat with the boat attached.
Any thoughts from the suspension gurus?
CoopDogg
