Clean07Burb
- Joined
- Mar 25, 2014
- Posts
- 784
- Reaction score
- 18
About two weeks ago I installed a McGaughy 2/3 kit on my '07 Suburban. 2" drop spindles up front and 3" drop springs along with shock extenders out back. I noticed a couple things during installation, and after installation, of the spindles while out on the first drive. I'd like to know if these two things are the norm with all drop spindles or just the McGaughy's.
#1: The tapered recess in the top "arm" of the spindle isn't cut or reamed deep and/or wide enough for the whole upper ball joint stud to seat flush with the machined surface of the spindle. In other words, the upper ball joint's tapered shaft doesn't go all the way down into the spindle because the taper in the spindle isn't machined properly to allow for it. Make note that this was the case with both the left and right spindles, but the shaft still protrudes plenty deep enough through the spindle to install and torque the nut on the bottom side, so I'm not sure if this is really a problem or not, but figured it was worth getting opinions about. Is this normal? If so, are all quality drop spindles made this way, including BellTech's?
#2: I also noticed that I've lost a considerable amount of turning radius after installing the drop spindles. Places that I previously was able to make easy u-turns are now two point turnaround spots. I've owned and lowered many vehicles in the past, but this is my first experience with lowering a truck, so maybe this is just a side effect of lowering via drop spindles. Can anyone elaborate?
Thanks in advance for any facts and/or experiences you guys can offer!
