Mic/talk button on steering wheel not working after new radio install
djsassan
Android Auto kept dropping, so the solution was to install a new radio. Everything is working fine as I go through and reprogram things, except I discovered that the microphone activation button does nothing when pressed. This is the one on the steering wheel on the right hand side, above the end call button.
Is this a setting somewhere? I didnt realize how much I use this button until it wasnt available.
2023 Yuko. XL Denali
Thanks
Fless
Super Moderator
Elev 5,280
Might be helpful to know what you're working on (year, make, model) and what electronics you've put in place.
BigdawgR6
See if this helps.. Go into settings - apps and permissions- show all apps - google assistant and make sure it's enabled. If not, then this disables the Speak to feature.
D
djsassan
Apparently after the latest firmware update, you have to hold down the button for 2 secs instead of like before where you could just select it.
Chaveztech510
