More power liftgate problems
work_truck
Hello all,
I recently bought an 08 LTZ Tahoe with power lifgate.
When opening it makes a pretty scaring rapid popping noise when it first begins to open. It does open and close normally after that initial stutter.
It opens smoothly with a tiny bit of help.
I just replaced the struts with new ones, and it has the same symptoms.
I also took the cover off to check out the motor and everything looked ok, the stutter seemed to be coming from the motor and not the latch.
I've read I think every thread out there and none of them seem to describe this problem.
Any ideas?
GM Customer Service
Michigan
work_truck,
I understand that you are looking to resolve this issue yourself and I might not be able to give you any technical advice. If you find that you cannot resolve this issue yourself, I would be happy to look into this concern for you. Please private message me if I can be of any assistance.
Jennifer T.
GM Customer Care
Stratton Braun
Was there any resolution here or solution? I'm in the EXACT same boat, and what interesting is it doesn't seem to be as common as other issues with the liftgate.
I'd appreciate any help
Thanks
bruh2125
