My 2004 Tahoe throws a P0443 code
ueww40
My 2004 Tahoe throws a P0443 code intermittently. I know it has something to do with the EVAP system. Can anybody be a little more specific and may have an idea what I should look for? Thanks
Fless
Super Moderator
Elev 5,280
Most likely internal to the purge valve on the engine. If you don't have a way to test the electrical switching (test lights are cheap) like he does in the video below, you could just replace the purge valve. No guarantees without an actual diagnosis.
Scottydoggs
NJ
likely a bad purge solenoid, heres a vid of its location and removal. pretty easy job.
OR VietVet
Multnomah Falls
Military
Willamette Valley
On my 05, I had read so many posts here about these NBS rigs with evap problems and single parts replacement not working and money/parts thrown at the problem. So, I just replaced the entire evap system. Never a problem since and use GM parts.
midlifegoals
