ccapehartusarmyINF.(ret)
so after a couple of hours dealing with a sticking lifter getting that all squared wich i fixed BTW
i stopped at a friends house yesterday and rolled down the windows and smelt that sweet sweet smell
and i said "AWW F**K" and i looked under the front end and saw drip drip drip drip
and under the hood it appeared to be running down right under the top radiator hose and dripping off the drain plug so i figured the hose had a hole so i replaced it then after driving somemore it still leaked
so after much closer examination right under were the hose goes into the radiator there is aobut a 3 inch crack kinda small but it still leaked alot. So since im not able to get a new radiator till later this week i said what the hell try some stop leak, i poured that stuff in there i got from orileys and after about 10 minutes it stopped leaking completely i was astonished of course but that didnt last long because low coolant light came on
now my question is since its basically a crack in the plastic part of the radiator would there be any harm in maybe attempting to seal it up with like an industrial adhesive gorrilla glue or something like that
its a pretty small crack
and i hear bad things aobut stop leak im just curious if i screwed up by using that stuff
