My hoe rearend help
99HOEkidd
Little Rock,AR
Ok i been hearing a howl or like a grinding type of noise from my HOE for a lil min now trying to figure out what it is...
Well the other day im was driving home when all of the sudden my truck goes to shacking and i smelling some thing weird..
I pull over look under my truck oil splashed everywhere...
help me plz.... what i need to do.
99HOEkidd
Little Rock,AR
I hope a new seal and oil will work I'm going to break it down later in the morning, also get some brake pads to hold me over until I do a full brake job.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Your pads or worn but can't afford to do rotors and what not? Then get some decent pads but change both sides not just one side and leave second set as spares. If looking to upgrade I recommend powerslot blotted rotors and hawk SD pads. No cross drilled stuff and if into always hauling heavy loads then get the cryo treated ones.
---------- Post added at 11:35 AM ---------- Previous post was at 11:33 AM ----------
Retorq is right tho, if you are getting obvious physical disturbances in the truck that you can feel then you will have to take it apart to find out what is wrong.
onetimejob
