lowpost99
Lowpost99
My 00' NBS Tahoe was about 4 hrs into a 8hr road trip two weeks ago when I noticed the infamous lifter tick sound, and my pressure dipped from about 35-40psi to about 20psi. I stopped and checked the oil, and it showed that I was about 3 quarts low. I added a quart and continued on my way home, the lifter tick subsided and I checked the oil the next day, it showed about a quart overfilled.
Now for some additional background, about 20 months ago, I solved the infamous lifter tick sound at startup issue by pulling the cam covers off and cleaning the rockers arms and the push rods portholes at the bottom of them. All went well and the truck drove like a charm.
So I've been driving about for about two weeks since that road trip, and I found that the oil filer tube was installed poorly and oil was likely leaking from there as I saw a lot of buildup, so I removed the cam covers again to remove it and I found this mucus thick, black sludge coating the covers about an 1/8 in thick. I cleaned the cam covers with degreaser and scrubbed them clean. Then I discover that the rocker arm screws and the push rods are really locked in from burnt oil build up. I mean I've been spraying with brake cleaner and liquid wrench for 3 days and they are still really stuck in there. I got a few of the rockers off, but none of push rods want to come out. When I did it before they slid out very easily.
My question is before I break something trying to pry it loose, should I put the covers back on and run some kerosene or other motor flush chemical in the oil for about 15-20 mins and then come back to cleaning those parts after I drain the oil and whatever sludge it drags out? I'm afraid that even if I safely get them all out, they'll just clog up again when I crank the car up to warm the oil for an oil change
