Thanks Brian. I had no idea that there was a break-in procedure needed. I just googled it and found some good info.
I might just be lazy and copycat the setup that jyi786 did... or something similar
Do it, you won't be disappointed.
Regarding the break-in, I've found it to be generally true. For me, as soon as I finish the brake job, I do some really light driving, stop and go, for about 5 minutes, to make sure the brakes are not malfunctioning and will hold. Nothing too drastic. Once I'm confident there are no issues, I do the next step:
As soon as I find open clear road, I take it up to 60MPH, then stomp on the brakes to bring it to *almost* a full stop. So like from 60MPH down to 10MPH. I do this multiple times, till I can at the very least smell burning brake material (the pads). It is critical that you not stop all the way because you want the pad material to transfer into the rotor, but not "bake" into one section of the rotor, which will end up causing wobble.
I then drive around slowly, under 30MPH, till I get home, and when I do, I park the vehicle on a safe level place (the top of my driveway) WITHOUT APPLYING THE PARKING BRAKE. The reason for this is the same as above; don't want the pad material baking into one section of the rotor. Then I let it cool down completely. Once done, I take it for a spin, and then park as usual.
Doing this procedure has never failed me with all the times I've done a complete pad/rotor overhaul of ALL my vehicles. I always end up with nice, smooth braking for a really, really long time (50K miles +). Of course, this is just my procedure, others may have other procedures that work for them or that they prefer.
