Need Help in point of the transmission cooling pipe's sparepart
DJPoertsch
Hallo to my friends,
I need some help in point of my Tahoe LTZ 5.3. I have to replace the 2 transmission cooling pipes. So now i am here to ask you, what is the different between this parts,
I don't know if i would order the right part if i would take the Dorman part.So here are the part nummbers that i find for my Truck.
1. Dorman Oilcooler Hose 625-209
2. ACDELCO 22802047 Outline
3. ACDELCO 15779543 Inline
Could you please tell me the different and what you recommend. I was plan to getting the Dorman product! But its up to you experts what you telling me to buy.
I show you an picture what i talking about.
Thanks to everybody Markus
Big Mama
Virginia
What year and why are you replacing it? If i see your picture correctly and there are 2 lines one goes into the cooler and the other comes out of the cooler.
DJPoertsch
DJPoertsch
Hallo Big Mama ,
You are right i forgot to tell you the car details. It's an 2007 Tahoe 5.3 regular gas LTZ 2WD. And you are right, this are this to lines they goes in to the cooler in front behind of the grill. One is the top Pipe and one is the bottom pipe. I think top one is Ingoing and the bottom one is outgoing.
Thanks for your help greetings Markus from Germany
Big Mama
Virginia
My pleasure Markus. The parts on line or in the catalog should clearly state which is supply and which is return. I haven’t had to replace mine but I’m assuming you have a leak? If so where?
DJPoertsch
DJPoertsch
Hallo Big Mama.. I have no leak at the moment. Only the survace ov the pipes have corrosion. So i want to replace them.
My concern was if I order the right parts. Because with the Dorman product is a valve block with it and in the other two articles, it is only the individual lines. I wanted to have another expert opinion so that I would not order the wrong parts. Because sending to Germany and sending it back is very complicated
mikeyss
Longmont, Colorado.
The difference between the individual lines and the lines with the 'block' is: the individual lines are for a 4 speed (4L60) transmission, while the other one with the lines connected is for a 6 speed (6L80) transmission.
DJPoertsch
DJPoertsch
Hallo @mikeyss
Good you are my hero. I was one step away to order the wrong one. Thank you so much. So i would see that i get the 2 single pipes. Because my Tahoe LTZ is only an 4 Speed transmission.
I am so happy not making an mistake in point of ordering this parts.
Great help from you
mikeyss
Longmont, Colorado.
I just looked again at the picture with the block with the hoses attached and just realized, those lines are for an engine oil cooler. I'm really glad you didn't order the block one, that one attaches to the engine and not for the transmission.
DJPoertsch
DJPoertsch
Thank you very much... safe money and don't waste time with the wrong parts. Now i start ordering the right parts. Thanks to all here at my post.
Greetings Markus
ezmoney1981
