Hi Elizabeth, No I didn't take it to the dealer, thinking that they would charge me for the diagnosis since the car is out of warranty. Yes it is the first time that this has happened, very weird, but it turned on at night, like if nothing had ever happened. Thanks
I'm gonna ask a stupid question maybe....
....but have you tried pushing the various buttons on the
display center thingie to see what happens?
llllljrlllll,
I am glad that it turned back on. If this issue happens again, please contact me.
Thank you!
Elizabeth, GM Customer Service
I had a digital speedometer display in a 1995 Chevrolet Caprice police car. The display was doing this exact same thing, off and on. The dealer replaced it for the county under warranty once. The second time it was not under warranty, so I got innovative, tore the dash apart, and trouble shooted the problem myself. I discovered the contact points between the display module (about the size of a pack of cigarettes) and the electrical contacts in the instrument cluster where you plug the module in were not touching. Bottom line, it didn't need replacing the first time most likely.
Sounds like something of this sort taking place in your truck maybe. Something is not making contact.
Just go slow while you're tearing the dash and instrument cluster apart. Don't want to break any of the plastic parts. And of course, don't go any further than you aboslutely have to in order to find and fix the probalem. I think you can find the loose connections.
If it's not a loose connection, it's probably going to be some sort of electrical module going bad.
[/COLOR]
Hi Elizabeth,
It turns on and off, it's a pain, I have to hit the cluster with my hand to actually turn it on now, I believe something is loose, I don't know if you can help me since i'm actually out of warranty already. But if you can, I would be a happy man. Thanks.
