Milz77
- Joined
- Jan 18, 2016
- Posts
- 39
- Reaction score
- 28
Hi Folks,
Dropped by 2013 Tahoe using Tony's kit 2/3 Belltech with 2" Drop Spindles and adjustable struts, SP shocks, cornering kit, etc.
I dropped the front 2" and back 3" however the front is too low and rubbing on inside of fender.
I didn't measure prior to drop however after drop the front is 32 3/4 and rear is 34 3/8 so approximately a 2" difference between front and back. The front strut currently has the 10mm spacers in and from what I read, I will need to add (2) 8mm spacers to raise one inch and (4) spacers to raise 2 inches.
My questions is twofold:
- If I add (4) spacers to raise 2 inches, this should "level" the vehicle which is what I am looking for as I run 24" KMC Slides in summer.
- Can I still use the 2" drop spindles when raising it another 2" or should these be removed and OEM spindles reinstalled?
Please help!
Please help!
